The Group Address feature enables you to create a group. You can register different types of destinations (such as e-mail, I-fax, or file server destinations) as a single group.
You can register up to 256 destinations in a group address.
If you want to store a group address, the destinations must be stored beforehand, such as e-mail, I-fax, and file server addresses.
(Settings/Registration).
[Access No.] appears on the screen only if [Manage Address Book Access Numbers] is set to 'On' in [Set Destination] (Settings/Registration). (See "Managing the Address Book with Access Numbers.")
You can register only one mail box in a group address.
(numeric keys) → press [Confirm].|
If you want to store a group address, you can only select destinations registered in the same Address List.
You can register e-mail addresses, I-fax addresses, file server addresses, and locations to store the file in a group address.
You cannot send to a group address including a file server in which the Enter Password Each Time setting is set to 'On'. (See "Registering a File Server Address.")
