Registering/Editing/Deleting Favorite Settings Buttons
You can register up to nine combinations of favorite copy settings.
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see "Optional Products Required for Each Function."
To register/edit a favorite settings button, set the Copy mode in advance.
Press [Function Settings] → [Copy] → [Register/Edit Favorite Settings].
To register a favorite settings button:
To edit a favorite settings button:
To delete a favorite settings button:
If you want to change the name of a button, select the button to change → press [Rename] → enter the new name.
Select a button ([M1] to [M9]) to register copy settings → press [Register].
Press [Yes].
If you press [Check Content], the existing registered settings appear.
Select a button ([M1] to [M9]) to overwrite settings → press [Register].
Press [Yes].
Select a button ([M1] to [M9]) to delete → press [Delete].
Confirm the contents to be deleted.
Press [Yes].
The name for the button is not deleted. To change the name of the button, press [Rename].
Press [Close].
» Settings/Registration » Function Settings » Copy » Registering/Editing/Deleting Favorite Settings Buttons
0S9Y-146
