Flow of Operations for Administrators
If the System Manager Settings (System Manager ID/System PIN) are set
Press
(Settings/Registration).
Press [Log In].
Specify the following.
Press [System Manager ID] → enter the Department ID.
Press [System PIN] → enter the PIN.
4.
Press [Log in].
If the System Manager PIN is still the default setting, a screen prompting you to change the System Manager PIN appears. Change the PIN according to the instructions on the screen.
Make sure that you do not forget the System Manager PIN. If you forget the System Manager PIN, contact your local authorized Canon dealer.
5.
Display the desired setting from the list.
6.
Specify the setting → press [Close].
To move up one level, press [Up].
7.
When you finish specifying the settings, press [Log Out] at the bottom right of the screen to log out.
You can also press
(Log In/Out) to log out.
If the System Manager Settings are set and Department ID Management is used
Press [Dept. ID] → enter a Department ID.
Press [PIN] → enter a PIN.
Press [Log in].
You can also press
(Log In/Out) to log in.
Press
4.
5.
6.
You can also press
