Do not turn the main power of the machine OFF while exporting/importing a Personal button/Shared button file, as doing so may cause the machine to malfunction.
Do not open and edit exported XML files, as this may cause the machine to malfunction.
To use the Remote UI, set [Remote UI] in [Management Settings] (Settings/Registration) to 'On'. (See "Remote UI.")
Only the System Manager can operate the Quick Menu Page. For information on the administrator, see "Administrator Settings."
Only administrator can export/import the Quick Menu from a computer.
You can also directly enter the file path.
Do not turn the main power of the machine OFF while importing a Personal button/Shared button file, as doing so may cause the machine to malfunction.
Specify the following settings if you are working in an environment using a proxy server. (As these settings differ depending on the network environment, consult the network administrator.)
In the proxy server settings of your Web browser, add the IP address of the machine or the computer name to the [Exceptions] (addresses that do not use a proxy) list.
Your browser requires the following settings: JavaScript should be enabled, and Cookies should be enabled for each session.
If Department ID Management is not set, the Log in screen is not displayed. For more information on Department ID Management, see "Department ID Management."
You can use the imported files of the Personal button/Shared button among the same models. However, you may not be able to use some imported buttons depending on the difference of the optional product attached and the surrounding environment.
Click [Log Out] to end the operation.
