(Main Menu) to return to the Main Menu.
If you turn OFF the main power switch when there is a job waiting to print, that job is erased.
It may take 60 minutes at the longest for the power to be turned off.
For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "Main Power and Energy Saver Key."
WARNING |
Do not connect or disconnect the power cord with wet hands, as this may result in electrical shock.
CAUTION |
Always grasp the power plug when disconnecting the power cord. Pulling on the power cord may expose or snap the core wire, or otherwise damage the power cord. If the power cord is damaged, this could cause current to leak, resulting in a fire or electrical shock.
When you contact your local authorized Canon dealer, have the following information available:
Product name
Details of the malfunction
The error code displayed on the touch panel display
: Available -: Unavailable|
Available Functions
When the Print function is restricted:
When the Scan function is restricted:
Copy
Scan and Send
Scan and Store
*1 |
Access Stored Files
*2 |
Fax/I-Fax Inbox
Remote Scan
Shortcut to Settings/Registration
Available Functions
Quick Menu*3
The Status Monitor/Cancel Screen
*4 |
Available Functions
Remote UI
*1
[Print List] on the Mail Box Selection screen is not available.
*2
[Add Files (Scan and Store)] on the Edit File screen is not available.
*3
The registered button may not be available depending on the restricted functions.
*4
[Print List] on the Job Log screen is not available.
A print job is automatically canceled when the Print function is restricted. A scan job is automatically canceled when the Scan function is restricted.
The machine may not enter the Sleep mode completely when a function is restricted due to an error.
If the target function is restricted due to an error, the function is not available when you use the shortcut key on the top of the Main Menu screen or when you use the Quick Menu.
[Remove Toner Cartridges] is not available when the Print function is restricted.
