Sending Data to a File Server
The following system requirements need to be met and the following operations and configurations need to be performed in order to send data to a file server from the machine.
The following network and system environments are compatible when sending data from the machine to a file server, depending on the type of network used:
When using FTP
Windows Server 2003 R2 SP2 and Internet Information Services (IIS) 6.0
Windows Vista SP and IIS 7.0
Windows Server 2008/R2 and IIS 7.0
Windows 7 and IIS 7.5
Windows 8 and IIS 8.0
Windows Server 2012 and IIS 8.0
Solaris 10
Red Hat Linux 9
When using WebDAV
Windows Server 2003 R2 SP2 and IIS 6.0
Windows Vista SP2 and IIS 7.0
Solaris 10 and Apache 2.0 or later
Red Hat Linux 9 and Apache 2.0 or later
Solaris 10 and openssl 0.9 or later
Red Hat Linux 9 and openssl 0.9 or later
When using and SMB/CIFS network
Windows Vista SP2
Windows 7
Windows 8
Windows Server 2012
Red Hat Linux 9 and Samba 2.2.8a or later
You can send data over a TCP/IP network to any of the following:
FTP server (Windows Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012, UNIX, Linux)
WebDAV server (Windows Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012, UNIX, Linux)
Windows sharedfolder (Windows Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012)
Samba shared folder (UNIX/Linux)
This section describes how to set up a computer as an FTP/WebDAV server.
Samba 2.2.8a or later is supported.
This section describes only the procedures for setting up a computer receiving data sent from the machine. To send data from the machine to a server on the network, you must enter an address setting from the control panel. For instructions on specifying recipient address settings, see "Specifying Destinations."
The following procedure explains a sample FTP/WebDAV server setup. Depending on your environment, the actual setup procedure may differ.
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
You can send data over an SMB/CIFS network to any of the following:
Windows shared folder
This section describes how to configure a shared folder.
This section describes only the procedures for setting up a computer receiving data sent from the machine. To send data from the machine to a server on the network, you must enter an address setting from the control panel. For instructions on how to specify recipient address settings, see "Specifying Destinations."
The following procedures describe a sample shared folder configuration. Depending on your environment, the actual setup procedure may differ.
1. Connect the machine to the network.
2. Specify the network settings.
For details, see the manual provided with the imagePRESS Server.
3. Set the key pair used with SSL encrypted communications.
