e-Manual
Top
Site map
Help
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products
Software
Settings/Registration
Paper Type Management
Adjustment for Image Quality and Finishing (Calibration)
Maintenance
Problem Solving
Copy
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Quick Menu
Status Monitor/Cancel
Remote UI
Security
How to Use This Manual
Expand All
Collapse All
Category Top
Operations Required Prior to Using the Machine
Logging In to the Machine as an Administrator
Connecting to a Network
Sending E-Mail/I-Faxes
Sending Data to a File Server
FTP Server Settings
WebDAV Server Settings
Connecting to an SMB/CIFS Network and Configuring a Shared Folder
Using the Machine as a Scanner
Managing the Machine from a Computer
Connecting the Machine to an External Network and Registering/Updating Software
Registering/Updating Software Without Connecting the Machine to an External Network
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Optional Products
Software
Maintenance
Problem Solving
Copy
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Quick Menu
Remote UI
Security
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
ยป
Flow of Settings
Flow of Settings
0S9Y-007
Not sure which optional products and which settings are required to use the functions you need?
This category introduces the flow of settings to perform before using each function.
Back to Top
