      0WR6-0WU
      <Common Settings>
      You can register/change the common settings for receiving faxes/I-faxes.
      Item
      Description
      <Print on Both Sides>
      You can select whether to print received documents on both sides of paper.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <Select Drawer>
      You can set how the machine prints documents when there is no paper matching the size of the received document. There are four printing methods.
      <Switch A>
      The image is printed over two sheets of paper that have the same combined size as the received document.
      <Switch B>
      The image is printed with blank space on paper that has the same width as the received document.
      <Switch C>
      The image is reduced and printed on paper that differs in width from the received document.
      <Switch D>
      The image is printed on paper that is larger in size than the received document.
      Setting Value
      <Switch A>: <On>, <Off>
      <Switch B>: <On>, <Off>
      <Switch C>: <On>, <Off>
      <Switch D>: <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Reduce Fax RX Size>
      You can select whether to automatically reduce received documents so that the whole document is printed within the printable area of the paper.
      IMPORTANT:
      If the area of the image which exceeds the printable area is less than 1/2" (12 mm), the image will not be printed, regardless of the settings specified here.
      Setting Value
      <On>, <Off>
      When <On> is selected
      <Reduction Mode>: <Auto>, <Fixed>
      <Reduction %>: 75 to 90 to 97%
      <Reduction Direction>: <Vertical & Horizontal>, <Vertical Only>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <2 on 1 Log>
      You can select whether to print received documents of the same paper size onto a single sheet of paper. This setting is only available under the following conditions:
      You must select the same paper drawer for printing two consecutive pages of a received document.
      The paper in the selected paper drawer must be large enough for two consecutive pages to be printed out.
      For example, if the LTR paper drawer is empty, but the 11" x 17" drawer is loaded, you can print two LTR documents onto a single sheet of 11" x 17" paper. On the other hand, if the 11" x 17" paper drawer is empty but the LTR drawer is loaded, you can print a reduced 11" x 17" original on LTR paper.
      Setting Value
      <On>, <Off>
      NOTE:
      If you set to <On>, documents are printed with a dotted line in the middle. If you print the document with sender information, the dotted line is not printed in the area where the sender information is located.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Print RX Page Footer>
      You can select whether to print information, such as reception time and page number, at the bottom of received documents.
      Setting Value
      <Print>, <Do Not Print>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Interrupt and Print RX Jobs>
      You can set to suspend other jobs to print faxes/I-faxes when the machine receives them.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Use Forwarding Settings>
      You can select whether to forward received documents to other destinations such as the Confidential Fax Inbox of the machine and an external file server. If you select <On>, specify the forwarding condtions in <Forwarding Settings>.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Handle Files with Forwarding Errors>
      You can set how the machine handles documents that fail to be forwarded.
      Setting Value
      <Always Print>, <Store/Print>, <Off>
      NOTE:
      If you set <Common Settings>  <Delete Failed TX Jobs>  <Off>, the documents with forwarding errors will be saved on the <Status Monitor/Cancel> screen, and the documents will not be processed according to the settings you specified here.
      DeviceAdmin: Yes
      NetworkAdmin: No
      You can specify the conditions for forwarding received documents. You can also set to forward all incoming documents to a specified destination without specifying any conditions.
      Setting Value
      <Receive Method:>: <All>, <Fax: Line Shared>, <Fax: Line 1> to <Fax: Line 4>, <I-Fax>, <Fax: IP Fax>, <Fax>
      <Search>
      <Validate/Invalidate>: <On>, <Off>
      <Delete>
      <Forward without Conditions> (→)
      <Register> (→)
      <Details/Edit> (→)
      <Print List>
      <E-Mail Priority>: <High>, <Normal>, <Low>
      <Receive Method:>: <Fax: Line 1> to <Fax: Line 4>, <I-Fax>, <Fax: IP Fax>, <Fax>
      <Forwarding Destination> (→)
      <File Name>: Enter a file name.
      <Store/Print Received File>: <On>, <Off>
      File formats: <TIFF>, <PDF> (→), <XPS> (→), <Divide into Pages>
      <Forwarding Done Notice>: Enabled, Disabled
      <Notice Only for Errors>: Enabled, Disabled
      <Register>
      <Previous Settings>: <History 1>, <History 2>, <History 3>
      <Condition Name>: Enter a condition name.
      <Conditions> (→)
      <Specify Fwd. Time> (→)
      <Details/Edit>
      <Conditions> (→)
      <Specify Fwd. Time>: (→)
      <Address Book>: Select a forwarding destination from the Address Book.
      <Confidential Fax Inbox>: Select a box as a forwarding destination.
      <PDF>
      <OCR (Text Searchable)>, <Add Digital Signatures> (→)
      <Device Signature>, <Visible Signatures>
      <Conditions>
      <Receive Method:>: <Fax: Line Shared>, <Fax: Line 1> to <Fax: Line 4>, <I-Fax>, <Fax: IP Fax>, <Fax>
      <Fax Number>: <Disregarded>, <Equals>, <Differs from>, <Begins with>, <Ends with>, <Contains>, <Does Not Contain>
      <Subaddress>: <Does Not Exist>, <Equals>
      <Password>: <Does Not Exist>, <Equals>
      <Specify Fwd. Time>
      <Everyday>, <Specify Period>, <Off>
      <XPS>
      <Add Device Signature>
      NOTE:
      If the selected destination is a group address which contains a Mail Box, the file you are sending will not be forwarded to (and stored in) that Mail Box.
      If you select <I-Fax> for <Receive Method:>, you cannot specify a WebDAV server as the forwarding destination. If the selected destination is a group address which contains a WebDAV server, the document is not forwarded to the WebDAV server.
      You cannot select multiple destinations at the same time. To forward to multiple destinations, select a group address.
      If you set both <Store/Print Received File> and the Memory Reception function to <On>, the received document is stored in the Memory RX Inbox. If you set the Memory Reception function to <Off>, the received document is printed automatically.
      DeviceAdmin: Yes
      NetworkAdmin: No
      You can specify the settings for the Confidential Fax Inbox and the Memory RX Inbox.
      <Always Send Notice for RX Errors>
      You can select whether to notify the sender that an I-fax was not received successfully.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
