      0WR6-0JX
      <License/Other>
      You can register licenses and configure the settings related to the software and system options available for the machine.
      Item
      Description
      <Register License>
      Enter the license key for a system option that can be used on the machine. Installing System Options
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      You can print a report on Multifunctional Embedded Application Platform (MEAP), and also configure the settings related to TLS communication used when a MEAP application is used.
      <Remote UI>
      Select whether to use the Remote UI to operate the machine and change settings. Starting the Remote UI
      Setting Value
      <On>, <Off>
      <Use TLS>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      Device Information Distribution Available: Yes
      <Delete Message Board Contents>
      Select to delete messages from the administrator that are displayed on the control panel. Displaying Messages from the Administrator
      IMPORTANT:
      When <OK> is displayed on a message board, press <OK> to operate the machine. To clear a message board that does not contain the <OK> button, you need to use the Remote UI.
      Setting Value
      <Yes>, <No>
      DeviceAdmin: No
      NetworkAdmin: No
      <Remote Operation Settings>
      Select whether to enable the Remote Operation function. This function enables you to specify settings and process jobs from a computer by displaying the screen of the touch panel display on the computer screen.
      Setting Value
      <On> (→), <Off>
      <On>: Enter the password.
      NOTE:
      For information on functions and operating instructions, see the instruction manual of the Remote Operator's Software Kit on the Canon official Web site.
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      <Use ACCESS MANAGEMENT SYSTEM>
      Select whether to use ACCESS MANAGEMENT SYSTEM. Using ACCESS MANAGEMENT SYSTEM
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Register/Update Software>
      You can install system options/MEAP applications in the machine using the <Register/Update Software> function.
      Setting Value
      <Install Applications/Options> (→), <Software Management Settings> (→)
      <Install Applications/Options>: <License Access Number>
      <Software Management Settings>: <Select Log Display> (→), <Test Communication> (→)
      <Select Log Display>: <Display Update Logs>, <Display System Logs>
      <Test Communication>: <Yes>, <No>
      DeviceAdmin: No
      NetworkAdmin: No
      <Start Setup Guide>
      You can follow the wizard instructions to configure the machine's initial settings. Setting up Using the Setup Guide
      Setting Value
      <Enable>: Starts Setup Gudie.
      DeviceAdmin: No
      NetworkAdmin: No
