      0WR6-0JY
      <MEAP Settings>
      You can print a report on Multifunctional Embedded Application Platform (MEAP), and also configure the settings related to TLS communication used when a MEAP application is used.
      Item
      Description
      <Print System Information>
      You can print information for MEAP applications and certain system applications as a report.
      Setting Value
      <Yes>, <No>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Use TLS>
      Select whether to use TLS communication when a MEAP application is used by accessing the machine via a Web browser.
      Setting Value
      <On>, <Off>
      NOTE:
      You need to configure the key and certificate before setting this setting to <On>. Configuring the Key and Certificate for TLS
      Changes made for this setting are also applied to <Use TLS> in <Remote UI>. <License/Other>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      <Confirm TLS Certificate Using MEAP Application>
      Select whether to verify TLS server certificates and their common names (CN) when TLS communication is used for a MEAP application.
      Setting Value
      <On> (→), <Off>
      <On>
      <Add Items to Verify>: <CN>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
