      0WR6-07U
      Skipping Blank Pages When Scanning
      The machine can detect and skip documents with blank pages when scanning.
      1
      Place the document. Placing Documents
      2
      Press <Scan and Send> on the Main Menu. <Main Menu> Screen
      3
      Specify the destination on the Scan Basic Features screen. Scan Basic Features Screen
      4
      Specify the scan settings as necessary. Basic Operations for Scanning Documents
      5
      Press <Options>  <Skip Blank Originals>.
      6
      Select the color of the documents to skip.
      To skip blank documents regardless of their color, select <All Colors>. To skip blank documents only in white, select <White Only>.
      NOTE:
      Pressing <Preview> to select the button enables you to check the contents of the scanned documents on the preview screen.Checking Scanned Documents Before Sending/Saving (Preview)
      7
      Press <Adjust Recog. Level>, set the accuracy to detect blank paper, and then press <OK>.
      Pressing <-> and <+> makes the detection accuracy lower and higher, respectively. When text and images on the document are faint, set a lower level of detection, and when dark borders and dirt appear on the document, set a higher one.
      8
      Press <Close>.
      9
      Press .
      Documents are scanned and sending/saving starts.
      To check the number of documents that have been sent/saved, follow the procedures below:   <Send> <Job Log> select a document <Details> check the number displayed for <Send Pages>
      The status screen and Communication Management Report display the number including blank paper. Checking Status and Log for Scanned Documents
