      0WR6-022
      Logging into the Machine
      When the login screen is displayed, registered authorized users are required to log in to continue operating the machine. The items displayed on the login screen vary depending on the user management settings. Log in based on the items that are displayed.
      If <Auto Reset Time> is set, the user is automatically logged out when no operations are performed for a specified period. <Timer/Energy Settings>  <Auto Reset Time>
      When the Icon List Is Displayed
      Press your icon. If a PIN code has been set, enter your PIN code and press <OK>  <Log In>.
      You can change the display order or narrow down the icons that appear in the drop-down list at the top-right of the screen.
      When you finish using the machine, press <Log Out> or to log out.
      When the User Name and Password Input Screen Is Displayed
      Use the on-screen keyboard to enter the user name and password.
      1
      Press <User Name>.
      You can also select the user name from the login history drop-down list. When a user name is selected, press <Password> and proceed to step 3.
      2
      Enter the user name and press <Next>.
      3
      Enter the password and press <OK>.
      4
      Select the login destination from the <Login Destination> drop-down list, and press <Log In>.
      When login is successful, the machine functions become available.
      You can log into the machine using the IC card or copy card. For details about the IC card, contact your local authorized Canon dealer. For details about the copy card, see Copy Card Reader-F1.
