      0WR6-0LE
      Adjusting Print Density
      When you make a copy without adjusting density and there is a significant difference between the image density of the output paper and that of the document, follow the procedure below to adjust the density.
      1
      Press   <Adjustment/Maintenance>  <Adjust Image Quality>  <Correct Density>.
      2
      Adjust the density.
      3
      Press <OK>.
