      0WR6-02L
      Customizing the Basic Features Screen
      The setting buttons that are displayed on the Basic Features screens (for copy, fax, and scan) can be changed. By locating frequently used setting buttons on the Basic Features screen, you can use functions more efficiently.
      Copy Basic Features screen
      Fax Basic Features screen
      Scan Basic Features screen
       Buttons that can be replaced
      Example: Copy Basic Features screen
      1
      Press <Copy> on the Main Menu and press .
      2
      Press <Register Options Shortcuts>.
      3
      Select a button to be replaced.
      Buttons displayed here are currently being displayed on the Basic Features screen. Buttons selected in this step will not be displayed on the Basic Features screen.
      4
      Select a button you want to display on the Basic Features screen and press <OK>.
      If you do not want to display the button, press <Unassigned>.
      5
      Press <OK>.
      By replacing with the button selected in step 3, the new button selected in step 4 is displayed on the Basic Features screen.
      The number of setting items located on the Basic Features screen and the location to be displayed differ depending on functions.
      If you have changed the Copy Basic Features screen to the Express Copy screen (Changing the Settings Quickly (Express Copy Screen)), select the button in step 3 and then press <Register>.
      TIPS
      Registering in <Favorite Settings>
      In <Favorite Settings>, you can register frequently used procedures for copying, as well as frequently specified destinations and settings for scanning. For more information on copying, see Registering Frequently Used Copy Settings, and for more information on scanning, see Useful Scanning Functions.
      Changing the default setting on the Basic Features screen
      After changing the settings for each function, you can register the current settings as a default on the Basic Features screen by pressing  followed by <Change Default Settings>. If you log into the machine with personal authentication management (Logging into the Machine) before performing this setting, it is registered as your own personal default setting.
