      0WR6-058
      Registering Frequently Used Copy Settings
      If you frequently copy with the same settings or want to hold complicated settings for later use, register the settings as "Favorite Settings." You can conveniently recall them whenever you need.
      Registering Copy Settings
      1
      Press <Copy> to specify the copy settings that you want to register. Basic Copy Operations
      2
      Press <Favorite Settings> on the Copy Basic Features screen. Copy Basic Features Screen
      3
      Select a button and press <Register>.
      To change the button name, select the button, press <Rename>, and enter a new name.
      To delete the registered setting, select the button and press <Delete>.
      4
      Press <Yes>  <Cancel>.
      You can register "Favorite Settings" from  located in the upper-right of the Copy Basic Features Screen. Copy Basic Features Screen
      The Merge Job Blocks setting (Combining Jobs with Different Settings Into a Single Job (Merge Job Blocks) cannot be registered.
      Recalling Registered Settings Before Copying
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      4
      Select the button and press <OK>  <Yes>.
      You can change the details of the recalled setting after pressing <Yes>.
      5
      Press .
      Copying starts.
