      0WR7-05H
      Receiving Faxes
      When a fax is received
      The [Processing/Data] indicator on the control panel blinks green. When receiving is complete, the document is automatically printed and the indicator turns off.
      To cancel receiving, press   <Receive>  <Job Status>  select a document  <Cancel>.
      Output paper
      An incoming fax is printed on the same size of paper as the document size received. When there is no paper matching the size of the received document, the document is printed according to the setting of <Select Drawer>. <Common Settings>  <Select Drawer>
      To receive fax information services
      Follow the recorded message to enter the service number, and then press <Start RX>.
      Receiving with a subaddress
      The machine supports the use of ITU-T* standard subaddresses. To receive a document with a subaddress, see <Common Settings>  <Forwarding Settings>.
      * Stands for International Telecommunication Union-Telecommunication Standardization Sector, which is the group that makes recommendations towards the standardization of worldwide telecommunications.
      TIPS
      You can save paper when printing.
      You can include information, such as reception time, in received documents when printing. <Common Settings> <Print RX Page Footer>
      If you set the machine to check a reception password for subaddress communication, you can prevent the machine from receiving spam faxes. <Fax Settings>  <RX Password>
      You can set the machine so that unprinted documents due to paper jams or lack of paper can be forwarded to the storage location (Memory RX Inbox) of the machine (<Set Fax/I-Fax Inbox>  <Forward Temporarily Stored File to Memory RX Inbox>). Forwarded documents can be printed later (Saving Received Documents in the Machine (Memory Reception)).
