Item
Description
<ECM RX>
You can receive faxes using the Error Correction Mode (ECM). ECM checks for fax data errors and corrects them.
IMPORTANT:
To perform a communication using ECM, ECM needs to be set in both the destination machine and this machine.
Even when you set ECM, errors can sometimes occur due to a poor telephone line connection.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<Fax RX Report>
A Fax RX Report is a report that enables you to check whether faxes were received correctly. The machine can be set to print this report automatically after documents are received or only when a reception error occurs. Fax RX Report
Setting Value
<For Error Only>, <On>, <Off>
NOTE:
Reports and lists can be printed on 11" x 17", LGL, or LTR paper. However, they may not be printable depending on the paper type.
DeviceAdmin: Yes
<Confidential Fax Inbox RX Report>
A Confidential Fax Inbox RX Report is a report that enables you to check whether documents were received in the Confidential Fax Inbox correctly. The machine can be set to print this report automatically after documents are received. Confidential Fax Inbox RX Report
Setting Value
<On>, <Off>
NOTE:
DeviceAdmin: Yes
<RX Start Speed>
You can change the receive start speed. This setting is useful when there is difficulty initiating the receivng of a document due to a poor line condition.
Setting Value
<33600 bps>, <14400 bps>, <9600 bps>, <7200 bps>, <4800 bps>, <2400 bps>
DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<RX Password>
You can set an ITU-T standard password. If a subaddress is not set in a document that was received from another party using the ITU-T standard, a reception password check takes place. If the password found does not match the password set with this setting, or if a reception password is not attached to the document, the document is not received.
IMPORTANT:
Priority is given to the subaddress password if the received document is set with a subaddress, even if a receive password is set.
NOTE:
ITU-T stands for International Telecommunication Union-Telecommunication Standardization Sector, which is the group that makes recommendations toward the standardization of worldwide telecommunications.
DeviceAdmin: Yes
