      0WR7-0W6
      Forwarding Received Documents Automatically
      You can set to forward received documents to specified destinations. Fax numbers as well as e-mail addresses and shared folders in computers can be specified as forwarding destinations.
      Forwarding All Documents Automatically (Forwarding All)
      The machine forwards all received documents to specified destinations. This method is useful when you want to get faxes even if you are out of the office. You can also set to print forwarded documents or receive an e-mail notifying you that forwarding documents is complete.
      Forwarding Automatically by Specified Conditions (Conditional Forwarding)
      The machine forwards received documents that only match the specific conditions, such as sender's fax number and received dates/times. For example, you can set conditions such as forwarding documents from Company A to all branch offices and forwarding documents received on holidays to e-mail addresses. Just like with the Forwarding All method above, you can also set to print forwarded documents or receive an e-mail notifying you that forwarding documents is complete.
      To forward documents automatically, some settings such as forwarding destinations and file formats of documents need to be specified beforehand. <Common Settings> <Forwarding Settings>
