Be careful of counterfeit toners
Please be aware that there are counterfeit Canon toners in the marketplace. Use of counterfeit toner may result in poor print quality or machine performance. Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner.
For more information, see canon.com/counterfeit. |
Hold the blue section of the toner cartridge with your left hand and lift the lower section with your right hand.
Pull it out horizontally toward you.
Hold the blue section of the toner cartridge with your left hand and uphold the lower section with your right hand.
Insert it horizontally as far as it will go.
Turn the locking lever completely to the left.
Close the toner replacement cover.
Printing that was suspended because the toner had run out will automatically resume once the toner cartridge is replaced.
If brightness and density differ after the toner cartridge is replaced, perform the following adjustment.
You can check the level of remaining toner. Checking Toner Level
Product Name
Supported Canon Genuine Toner
imageRUNNER ADVANCE 6575i / 6565i / 6555i
Canon GPR-38 Black Toner
