      0WR7-0KY
      Adjusting Gradation
      If the printing result is significantly different from the original document when you copy an image, you can perform the auto adjustment to correct the gradation.
      Adjustments may not be performed effectively if there is not sufficient toner. Checking the Remaining Amount of Consumables
      1
      Press   <Adjustment/Maintenance>  <Adjust Image Quality>  <Auto Adjust Gradation>.
      2
      Select the paper source in which plain paper is set and press <OK>.
      3
      Press <Start Printing> to print a test page.
      A test page is printed.
      NOTE:
      Use this test page, which has a black stripe for adjustment.
      4
      Place the test page on the platen glass.
      Place the test page with the print side face down so that the black stripe is toward the back side of the machine.
      5
      Close the feeder and press <Start Scanning>.
      The machine starts scanning the test page.
      6
      Open the feeder, and remove the test page.
      7
      Repeat steps 3 to 6 a total of three times.
      To complete the adjustment, print the test page three times, and scan it each time it is printed.
