Checking Status and Log for Sent and Received Documents
You can check the statuses and communication logs for sent and received documents.
Checking the Statuses for Sent Documents
1
Press
![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_key_sysmon.gif)
2
Press <Send>
![](./images/book_images/b_in_arrow_right.gif)
<Job Status>.
To display only fax documents, select <Fax> from the drop-down list in the upper-right of the screen.
3
Check the statuses.
Selecting a document and pressing <De- tails> enables you to check detailed information such as the destinations and the number of pages.
Selecting a document and pressing <Cancel> enables you to cancel sending.
Pressing <Print List> prints a status list of sent documents displayed on the screen.
Pressing <De- tails> ![](./images/book_images/b_in_arrow_right.gif) <Resend> enables you to resend the documents that failed to send. To specify another destination, press <Change Destination>. For documents with multiple destinations specified using the same sending method, press <Broadcast List>, select a destination, and then press <Resend> or <Change Destination>.
You can resend documents when <Delete Failed TX Jobs> is set to <Off> ( <Delete Failed TX Jobs>). Note that you cannot resend the documents sent with Direct Send/Manual Sending/PC fax.
You can change the destinations of documents that are set to be sent at a specified time as well as documents that failed to send. Note that you cannot change the destinations for documents with multiple destinations specified that are being sent, or when entering a new destination is restricted ( Limiting Available Destinations).
Checking the Statuses for Received Documents
1
Press
2
Press <Receive>
<Job Status>.
3
Check the statuses.
Selecting a document and pressing <De- tails> enables you to check detailed information such as the sender's names and the number of pages.
Selecting a document and pressing <Cancel> enables you to cancel receiving.
Checking If Documents Are Sent or Received Successfully
1
Press
2
Press <Send> or <Receive>
<Job Log>.
3
Check if documents are sent or received successfully.
<OK> is displayed in the <Result> column when a document was sent or received successfully. If <NG> is displayed, this shows that a document failed to be sent or received because it was canceled or there was some error.
Selecting a document and pressing <De- tails> enables you to check detailed information about the document. A three-digit number in the <Error Code> column on the information represents an error code. You can check the causes and solutions for errors based on error codes.
Countermeasures for Each Error Code
Pressing <Communic. Mgt. Report> or <Fax Activity Report> prints a log list of sent and received documents displayed on the screen or sends a file.
Specifying an address in the log and pressing <Register Destinations> enables you to register it to the Address Book or one-touch buttons.
LINKS
