Receiving Faxes
When a fax is received
The [Processing/Data] indicator on the control panel blinks green. When receiving is complete, the document is automatically printed and the indicator turns off.
To cancel receiving, press   <Receive>  <Job Status>  select a document  <Cancel>.
Output paper
An incoming fax is printed on the same size of paper as the document size received. When there is no paper matching the size of the received document, the document is printed according to the setting of <Select Drawer>. <Select Drawer>
To receive fax information services
Follow the recorded message to enter the service number, and then press <Start RX>.
Receiving with a subaddress
The machine supports the use of ITU-T* standard subaddresses. To receive a document with a subaddress, see <Forwarding Settings>.
* Stands for International Telecommunication Union-Telecommunication Standardization Sector, which is the group that makes recommendations towards the standardization of worldwide telecommunications.
TIPS
You can save paper when printing.
You can include information, such as reception time, in received documents when printing. <Print RX Page Footer>
If you set the machine to check a reception password for subaddress communication, you can prevent the machine from receiving spam faxes. <RX Password>
Setting <Forward Temporarily Stored File to Memory RX Inbox> to <Yes> enables you to forward received documents to the storage location of the machine (Memory RX Inbox) if they cannot be printed due to paper jams or lack of paper. In this case, <Fax Memory Lock>/<Use I-Fax Memory Lock> is automatically set to <On>, and forwarded documents can be checked from the screen. Also, forwarded documents can be printed later. (Saving Received Documents in the Machine (Memory Reception)) To return to normal printing, set <Fax Memory Lock>/<Use I-Fax Memory Lock> to <Off>.
13WJ-05S
