Adjusting the Color
Adjust the density of yellow, magenta, cyan, and black separately. You can also specify the vividness and tone to perform fine adjustment for the color.
1
Place the original.
Placing Originals
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Press <Color Balance>.
5
Press <-> or <+> for each color to adjust the color balance.
6
Perform other adjustment.
<Adjust Saturation>
To set the saturation for all colors, use the <Low> or <High> button for <All Colors>. To set each color separately, use the <Low> or <High> button for each color. When adjustment is complete, press <OK>.
<Adjust Hue>
To set the hue for all colors, use the
![](./images/book_images/b_in_btn_left.gif)
![](./images/book_images/b_in_btn_right.gif)
button for <All Colors>. To set each color separately, use the buttons to the left and right of each color. When adjustment is complete, press <OK>.
<Fine Adjust Density>
Select a color and adjust its density level by its density area using the <-> or <+> button. When adjustment is complete, press <OK>.
<Adjust Black Hue>
Adjust towards the side of <Lighter> to prevent the image from becoming over-darkened. Adjust towards the side of <Darker> if text and images are too light. When adjustment is complete, press <OK>.
7
Press <OK>
![](./images/book_images/b_in_arrow_right.gif)
<Close>.
8
Press
![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_key_Start.gif)
Copying starts.
TIPS
You can register up to four settings after adjustment. After adjusting the color, press <Recall/Register> ![](./images/book_images/b_in_arrow_right.gif) select a button from <C1> to <C4> ![](./images/book_images/b_in_arrow_right.gif) press <Register> ![](./images/book_images/b_in_arrow_right.gif) <Yes> ![](./images/book_images/b_in_arrow_right.gif) <OK>.
To recall registered settings, press <Recall/Register>, select a button, and press <OK>.
You can change the button names of <C1> to <C4>. Select the button to change, press <Rename>, and enter a new name.
To delete registered settings, select the button ![](./images/book_images/b_in_arrow_right.gif) press <Delete> ![](./images/book_images/b_in_arrow_right.gif) <Yes>.
