Selecting the Type of Original for Copying
You can select the optimal image quality for the copy depending on the type of original such as originals with only characters or magazines with photographs.
1
Place the original.
Placing Originals
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Press <Original Type>.
5
Select the type of original.
If you select <Text/Photo (BleedReduce)>, you can copy so that thin color backgrounds of pages such as magazine pages, as well as the reverse sides of pages, and subsequent pages are not also copied.
If you select <Printed Image>, you can copy printed photographs (photographs made with halftone dots) with optimal print quality.
If you select <Photo Printout>, you can copy photographs printed on photographic paper with optimal print quality.
6
Press <OK>
![](./images/book_images/b_in_arrow_right.gif)
<Close>.
If you select <Photo Printout> and copy, highlights may be blown out (areas with stronger brightness may become bright white). In this case, adjust the background density so that blow out does not occur. Press <Options> ![](./images/book_images/b_in_arrow_right.gif) <Density> ![](./images/book_images/b_in_arrow_right.gif) <Adjust> for <Background Density> ![](./images/book_images/b_in_arrow_right.gif) <+>.
7
Press
![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_key_Start.gif)
Copying starts.
