<Up>
<Advanced Box Details>
<Edit Personal Space>
Location currently displayed
are saved.
Files and folders saved
Total number of files/folders and number of selected files
and the number of files in the selection.
<Print>
<Folder Operations>
<Edit File>
<Display Image>
<De- tails>
<Clear Selection>
Display switch button
To change a file name
1
Select a file and press <Edit File>
<Change File Name>. |
2
Enter a file name and press <OK>.
To display the preview image of a file
1
Select a file and press <Display Image>.
2
After checking the preview image, press <Back>.
To print the file, press <Print>.
To check the detailed information of a file
1
Select a file and press <De- tails>.
2
After checking the detailed information, press <OK>.
To delete a file
1
<Delete>. |
2
Press <Yes>.
To scan and save documents
1
Set the original. Placing Originals
2
Press <Edit File>
<Add Files (Scan and Store)>. |
3
Specify the scan settings as necessary and press
.For scan settings, see Setting Screen and Operations for Scanning to Save.
To create a folder
1
Press <Folder Operations>.
2
Press <Create Folder>.
3
Enter a folder name and press <OK>.
4
Press <OK>.
To change a folder name
1
Display a folder whose name you want to change and press <Folder Operations>.
2
Select a folder and press <De- tails>.
3
Press <Rename Folder>.
4
5
Press <OK>.
To check the detailed information of a folder
1
Display a folder whose information you want to check and press <Folder Operations>.
2
3
To delete a folder
1
Display a folder to delete and press <Folder Operations>.
2
Select a folder and press <Delete>
<Yes>. |
