[Service]
[Service]
[Destination Server Address:]
[Search Depth (Router):]
[User Account ID for Authentication:]/[New Password:]
Automatically Discovering the Server MachineIn the following cases, synchronization can be set without performing step 5.
When the number of machines to synchronize is 10 or fewer, including the server machine (as long as the machines are within the same router).
When <Use User Authentication> is set to <On> on the server machine (see <Use User Authentication>) and User Authentication is set as the login service (see Changing Login Services)
When nothing is entered in [User Account ID for Authentication:] on the client machines (the item is null)
When the service for synchronizing custom settings is started on the server machine (if the machine is a server/client machine, the setting can be changed by starting the server service and the client service at the same time)
When there is only one server machine for synchronizing custom settings on the same network
If the network settings of the server machine include both IPv4 and IPv6, and if IPv6 is prioritized and the client machine disables IPv6, the client machine cannot connect via search. Enter the IPv4 address for the destination server address.
Checking the Communication Log for SynchronizationYou can check the communication log from the screen for synchronizing custom settings. The log can also be downloaded as a file.
"Warning" is recorded as the level when the server machine cannot communicate temporarily.
"Error" is recorded as the level when the maximum amount of data that can be registered has been exceeded or authentication with the server machine fails.
Simple Synchronization SettingsSynchronization of custom settings can be started from the control panel for Canon multifunction printers within the same router.
For the server machine:
Press <Management Settings> <Device Management> set <Synchronize Custom Settings (Server)> to <Enable>.For a client machine:
Press <Management Settings> <Device Management> set <Synchronize Custom Settings (Client)> to <Enable>.If the machine is used as a server/client machine, also set <Synchronize Custom Settings (Client)> to <Enable>.
Note When Canceling SynchronizationWhen a client machine cancels synchronization of custom settings, the client machine will become unable to retrieve the settings for each user registered in the server machine. Therefore note that the personalized data of a machine that was a client machine may not have the latest data after synchronization of custom settings has been canceled.
