[Start] in [SMS Installer Service (Password Authentication)].
[Switch] in [DepartmentID Authentication].
When DepartmentID Authentication is startedIf you click [Service Management Service] on the portal page of the Remote UI, the login screen to the SMS is displayed. "MeapSmsLogin" is set as the login password for the SMS.
If you log in with "MeapSmsLogin," the screen for changing the password is displayed. For security purposes, follow the on-screen instructions to change the password.
The password for the SMS can be changed later with [Change Password] in [System Management].
Return to User AuthenticationClick [Enhanced System Application Management]
[Change] in [User Authentication] restart the machine click [System Application Management] [Stop] in [SMS Installer Service (Password Authentication)]. |
1
Press
<Log In>. |
2
Enter <System Manager ID> and <System Manager PIN> and press <Log In>.
Immediately after the DepartmentID Authentication has started, both the System Manager ID and PIN are set as "7654321."
3
Press <Management Settings>
<User Management> <System Manager Information Settings>. |
4
Enter the necessary information and press<OK>.
Enter the same PIN again for confirmation, and press <OK>.
If you install the Copy Card Reader-F1 after changing the System Manager ID and PIN, the ID and PIN return to "7654321."
When the machine is equipped with the Copy Card Reader-F1, the numbers assigned to each card (1 to 1000 by the factory default) cannot be registered as the System Manager ID and PIN.
1
Press
<Management Settings> <User Management> <Department ID Management>. |
2
Press <On>.
If you want to manage only with the System Manager ID and PIN without implementing Department ID Management, press <Off>.
![]() If you want to return the login service to the User Authentication and use the Department IDs, set Department ID Management of the DepartmentID Authentication to <Off> and start the User Authentication. Then assign Department IDs to users and set Department ID Management of the User Authentication to <On>.
3
Press <Register PIN>
<Register>. |
4
Enter <Department ID> and <PIN>
press <OK>.Enter the same PIN again for confirmation, and press <OK>.
5
Press <OK>
<OK>. |
press <Log In>.
When Department ID Management is not implementedWhen only the System Manager ID and PIN are set without Department ID Management, you need to log in to the machine only when you want to configure the settings that require the administrator's authority. Press
<Log In>, enter <System Manager ID> and <System Manager PIN>, and press <Log In>. |
When Department ID Management is not implementedWhen only the System Manager ID and PIN are set without Department ID Management, the login methods differ between the system administrator and general users. For the system administrator, select [System Manager Mode] and enter [System Manager ID]/[System Manager PIN], and then click [Log In]. For general users, select [General User Mode] and enter PIN, and then click [Log In].
If you set <Allow> for <Access by General User>, you can select [General User Mode]. <License/Other>
<Remote UI> |
<User Management>
<Page Totals>
Check the page total
<User Management>
<Register PIN>
Select Department ID
<Edit>
<Turn Limit On/Off and Set Page Limit>
Press <On> for functions to restrict
Enter the number of pages
<OK>
<OK>
<OK>
<OK>
<User Management>
<Register PIN>
<Limit Functions>
Press <On> for functions to set Department ID Management on
<OK>
<OK>
<OK>
<User Management>
<Register PIN>
Select the Department ID
<Delete>
<Yes>
<OK>
<OK>
<User Management>
Set <Allow Printer Jobs with Unknown IDs> or <Allow Remote Scan Jobs with Unknown IDs> to <Off>
<OK>
<User Management>
Set <Allow Black & White Copy/Print Jobs> or <Allow Black & White Printer Jobs> to <Off>
<OK>
