Staple Jams in the Booklet Finisher
Clearing Staple Jams in the Staple Unit
1
Open the front cover of the finisher.
2
Pull out the staple case.
Hold the green handle on the staple case and pull it straight out.
3
Remove any jammed staples from the staple case.
Lift up the knob on the staple case.
Remove all jammed staples and exposed staples.
Return the knob on the staple cartridge to its original position.
4
Hold the green handle on the staple case and push it in as far as it will go.
5
Close the front cover of the finisher.
The finisher may automatically perform dry stapling to perform staple repositioning.
Clearing Staple Jams in the Saddle Stitcher Unit
1
2
Pull out the saddle stitcher unit.
3
Remove the (two) staple cases while pulling down the lever towards yourself.
4
Lower the knob on the staple case.
Return the knob on the staple case to its original position.
Take care not to be injured by staples.
5
Install the (two) staple cases to the saddle stitcher unit.
6
Gently return the saddle stitcher unit to its original position.
7
After clearing a staple jam, make sure to adjust the staple position.
<Saddle Stitch Staple Repositioning>
13WJ-0S4
