<Adjust Action>
This section describes the copy and print finishing settings, such as adjusting the saddle stitch position.
<Saddle Stitch Staple Repositioning>![](./images/global_images/1T0002134966/g_ne_toggle_open.gif)
![](./images/book_images/b_in_arrow_right.gif)
<Adjustment/Maintenance>
<Adjust Action>
Feeds papers to the saddle stitcher unit and staple them several times, and performs the saddle stitch staple repositioning procedure. The machine performs this adjustment procedure after you clear a paper jam or replace the staple cartridge.
Only use 330×482 mm, 320×450 mm, 305×457 mm, A3, B4, A4R, 11" x 17", LGL, or LTRR paper for the saddle stitch staple repositioning procedure.
Make sure to remove all output booklets from the booklet tray before performing the saddle stitch staple repositioning procedure.
Paper that is required for the saddle stitch staple repositioning procedure is automatically fed to the saddle stitcher unit by the machine.
<Change Fold/Stitch Position>
<Adjust Action>
If you notice that the saddle stitch position of the paper is not exactly in the middle of the booklet, you can make adjustments to the saddle stitch position to compensate for this error. Adjust the folding position of the paper and the saddle stitch position at the same time.
Adjusting the Saddle Stitch Position
<Adjust Saddle Stitch Fold Position>
<Adjust Action>
If you notice that the folds of the paper are not exactly in the middle of the booklet, you can make adjustments to the fold placement to compensate for this error. This mode enables you to adjust the folding position without changing the stapling position.
Adjusting the Saddle Stitch Folding Position
<Switch Finisher Puncher Mode>
<Adjust Action>
You can set whether to give priority to the punching speed or to precision.
<Adjust Fold Position>
<Adjust Action>
You can adjust the paper folding position.
Adjusting the Paper Folding Position
<Time Until Stapling Starts in Stapler Mode>
<Adjust Action>
You can set the time until stapling is performed after inserting paper when using manual stapling.
