<Paper Settings>
This section describes how to register paper to use.
<Paper Settings>
![](./images/book_images/b_in_arrow_right.gif)
<Preferences>
<Paper Settings>
You can register the paper size and type for each paper source. This setting enables you to achieve the appropriate print results.
Specifying Paper Size and Type in the Paper Drawer
<Paper Size Group for Auto Recognition in Drawer>
<Preferences>
<Paper Settings>
You can set the paper size group for each paper source to make the machine detect the loaded paper size automatically.
<A5R/STMTR Paper Selection>
<Preferences>
<Paper Settings>
When A5R or STMTR paper is loaded in the paper drawer, you can set the size to use for the operation.
<Paper Type Management Settings>![](./images/global_images/1T0002134966/g_ne_toggle_open.gif)
<Preferences>
<Paper Settings>
You can register/edit various customer paper types (user defined paper types), besides the default paper types registered in the machine.
Managing Paper Types
You can edit only user-registered paper types.
1
Press .
2
Press <Preferences> <Paper Settings>.
3
Press <Paper Type Management Settings> specify the settings.
Paper type drop-down list
Enables you to select the paper type to display.
![](./images/book_images/b_in_C0000_b.gif) <Sort List By>
Enables you to change the display order of the list.
![](./images/book_images/b_in_C0000_c.gif) <Details/Edit>
Displays details for the selected paper type on the <Details/Edit> screen. If you select a custom paper type, you can edit it.
![](./images/book_images/b_in_C0000_d.gif) <Duplicate>
Duplicates the selected paper type as a custom paper type.
![](./images/book_images/b_in_C0000_e.gif) <Delete>
Deletes the selected custom paper type.
![](./images/book_images/b_in_C0000_f.gif) <Change>
Appears on the <Details/Edit> screen for the custom paper type and enables you to change the settings for the selected item.
You can only edit/delete custom paper types.
If you specify incorrect paper settings, paper jams and image problems may occur.
The value you set here becomes the default correction width when the selected paper type is used for saddle stitching with automatic "Adjust Creep (Displacement) Correction".
4
Press <OK>.
<Register Favorite Paper (Multi-Purpose Tray)>
<Preferences>
<Paper Settings>
You can easily specify paper settings by registering paper frequently used in the multi-purpose tray in a button. "Favorite Paper" can be easily recalled from the screen displayed when paper is loaded.
Registering Frequently Used Paper Size and Type for the Multi-purpose Tray
<Multi-Purpose Tray Defaults>
<Preferences>
<Paper Settings>
Registering the default multi-purpose tray paper is convenient if you always use the same size and type of paper in the multi-purpose tray.
<Register Custom Size>
<Preferences>
<Paper Settings>
You can register frequently used free sizes of paper. The paper sizes registered here are displayed on the paper size selection screen for the paper drawer and multi-purpose tray.
Registering Free Size Paper (Custom Size Paper)
