Specifying Paper Size and Type in the Paper Drawer
1
Load the paper in the paper drawer. Loading Paper in the Paper Drawer
2
Press .
3
Press <Preferences>  <Paper Settings>  <Paper Settings>.
4
Check the paper size that is displayed.
When loading standard size paper, the paper size is automatically detected.
 (the top paper drawer),  (the second paper drawer from the top).
Depending on the options installed, the display differs.
If the displayed paper size is different from the loaded paper size, the paper may not be loaded properly. Load the paper again.
If <Custom> is displayed even though the standard size paper is loaded, press <Custom Size>  <Cancel Settings>. The correct size will be displayed.
When loading custom size paper
When loading envelopes
5
Select the paper source in which paper is loaded and press <Set>.
6
Select the paper type and press <OK>.
If the paper type loaded is not displayed, press <Detailed Settings> to select from a list.
7
Press <OK>.
8
Change the paper size label of the paper drawer as necessary.
Attach the paper size label at the same height as the cassette number indicator, and approximately 1/4" (5 mm) to the left.
* Approximately 5 mm
13WJ-02E
