Copy Card Reader-F1
If you install the "Copy Card Reader-F1" to the machine, you can perform Department ID Management using the control card. Users are required to authenticate themselves before starting an operation such as copying or faxing. Configuring the Department ID Management Settings
Card slot
Insert a control card.
Control card
Control cards used with the "Copy Card Reader-F1." You can manage up to 1,000 Department IDs.
Inserting a card
Removing the card
If you set the Server Authentication user authentication system of User Authentication as the login service (including when performing Server Authentication with the 'Server Authentication + Local Device Authentication' user authentication system), you cannot use the Copy Card Reader-F1. Managing Users
If the Main Menu screen does not appear when the control card is inserted, check if the control card is inserted in the correct direction and that the control card is not damaged or prohibited from use.
13WJ-0HY
