Inner 2way Tray-J1
Attach to use the following finish functions.
Collate
The printouts are collated into sets arranged in page order of the document.
Group
All printouts of the same original page are grouped together into sets.
Rotate 90 Degrees
Each printout group is rotated alternately in different directions.
TIPS
You can install both the Inner 2way Tray-J1 and Copy Tray-J2 to add an extra output tray. This is convenient for using a different output tray for each function, including the Copy, Print, and Fax functions.
Inner Tray
Paper is output to the output tray.
Output Paper Tray Guide
Tilt up the output paper tray guide to catch the printouts.
Main Unit's Right Cover
Open this cover when clearing a paper jam inside the main unit.
13WJ-0HS
