Using the USB Port
You can specify the settings related to the USB port.
Using the Machine as a USB Device
Press [Preferences] → [External Interface] → [USB Settings].
Press [Use as USB Device] → [On] → [OK].
Press [Off] to not use the USB device.
Using the MEAP Driver for USB Input Device Connections
Press [Use MEAP Driver for USB Input Device] → [On] → [OK].
Press [Off] to not use the MEAP driver for USB input device.
Depending on the type of MEAP application that uses device such as a keyboard or card reader, you may need to set this setting to 'On'. To check whether you need to set this setting to 'On', see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
Using the MEAP Driver for USB External Storage
Press [Use MEAP Driver for External USB Device] → [On] → [OK].
Press [Off] to not use the MEAP driver for USB external storage device.
Depending on the type of MEAP application that uses USB external memory device, you may need to set this setting to 'On'. To check whether you need to set this setting to 'On', see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
This mode is enabled only after you restart the machine. For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "Main Power and Energy Saver Key."
» Security » Device Management » Using the USB Port
08JK-293
