This function is displayed if the QR code is selected as the code for Document Scan Lock mode. (See "Selecting the Code for Document Scan Lock (TL Code/QR Code).")
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
(Settings/Registration).
For instructions on entering characters, see "Entering Characters from the Touch Panel Display." If you have registered characters in [Register Characters for Page No./Watermark] in [Function Settings] (Settings/Registration), you can select the characters from the list.
The Serial Number, which appears at the bottom left of the screen when you press
(Counter Check) on the control panel, is printed. |
If a login service has been set, the Department ID and user name of the user who is currently logged in to the machine are printed.
The watermark "CONFIDENTIAL" is printed if a login service is not set.
To print a pattern on the background of copy, select the background pattern from the Background Pattern drop-down list.
You can select [36.0 pt], [54.0 pt], or [72.0 pt] for the size of the text.
You can select magenta, cyan, or black for the color of the text.
To change the print orientation for characters, press [Print Vertically].
To use white letters on a colored background, press [White Letters on Colored Bkg.].
[Allow All]:
You can embed QR code which enables documents to be copied.
[Prohibit All]:
You can embed QR code which restricts copying documents. You cannot copy documents when [Prohibit All] is detected.
[Specify for Each Job]:
If you set this setting, you can select whether to embed QR code for each job from the Options screen in Copy and Access Stored Files functions.
When using the QR code, you can automatically embed tracking information that enables you to analyze by whom, when, and with which machine the document was output.
