Entry Mode
Example
Procedure
Alphanum.
Canon
Enter 'Canon'.
Symbol
Press [%].
If you make a mistake when entering characters, press or to position the cursor → press [Backspace] to delete the characters → enter the correct characters.
To delete all of the characters you have entered, press (Clear).
The available entry modes, and the maximum number of characters that you can enter vary, depending on the type of entries you are making.
If you often enter texts which consist of uppercase letters (e.g., AAAAA BBBBB CCCCC), select [On] for [Use Keyboard Shift Lock Feature] in [Preferences] (Settings/Registration). (See "Changing the Keyboard Shift Lock Feature Settings.")
If you often enter texts which begin with uppercase letters (e.g., Aaaaa Bbbbb Ccccc), select [Off] for [Use Keyboard Shift Lock Feature] in [Preferences] (Settings/Registration). (See "Changing the Keyboard Shift Lock Feature Settings.")
When entering characters on the SSO-H authentication screen or in MEAP application functions, the screen you actually see may be different.
For information on displaying the keyboard, see the description for each function.
