The Saddle Stitch and Divided Booklet modes can be set only if the Booklet Finisher-K1/Booklet Finisher-L1 is attached.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper or transparencies, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Make sure to place originals with a vertical (portrait) orientation vertically. If these originals are placed horizontally, the even numbered pages will be printed upside down.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the type and quantity of paper.
If you do not use the Booklet Scan mode, you cannot select the layout of two-sided originals.
If the Booklet Scan mode is not used, you cannot select [Auto] of the original.
If the Booklet Finisher-K1 is attached, the maximum number of sheets, including cover sheets, that can be saddle stitched is 20. If the number of sheets is 21 or more, the booklet is not saddle stitched.
If the Booklet Finisher-L1 is attached, the maximum number of sheets, including cover sheets, that can be saddle stitched is 16. If the number of sheets is 17 or more, the booklet is not saddle stitched.
The following shows the maximum number of sheets that can be folded at one time when [Fold Only] is selected:
If the Booklet Finisher-K1 is attached:
16 lb bond to 28 lb bond (60 to 105 g/m2): five sheets
29 lb bond to 80 lb cover (106 to 220 g/m2): three sheets
If the Booklet Finisher-L1 is attached: one sheet
You must select the same paper size for the cover page as that used for the main document.
If you are loading preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
If you are using Heavy 3 or Heavy 4 paper, you can only print on <Front Inside Cover> or <Back Inside Cover>.
When using Booklet Finisher-K1, use the paper shown below.
Main document: 16 lb bond to 80 lb cover (60 to 220 g/m2)
Cover paper: Up to 110 lb cover (300 g/m2)
When using Booklet Finisher-L1, use the paper shown below.
Cover paper: Up to 140 lb index (256 g/m2)
If you are loading the paper for the cover page into a paper drawer, you must load the paper face up.
If you are loading the paper for the cover page into the multi-purpose tray, you must load the paper face down.
If you are adding a cover, the maximum number of sets that the booklet tray can hold differs, depending on the paper weight for the cover page, paper weight for the output pages, and number of sheets to use.
If the Booklet Finisher-L1 is attached: 10 sets
If the Booklet Finisher-K1 is attached, the number of saddle stitched booklets that the auxiliary booklet tray can hold depends on the paper weight and number of sheets each booklet contains.
If the Booklet Finisher-L1 is attached, the number of saddle stitched booklets that the auxiliary booklet tray can hold depends on the paper type, paper weight, and number of sheets each booklet contains.
to adjust the correction width.|
You can set [Trim] only if you select [Fold + Saddle Stitch].
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch].
You can set [Adjust Fold Position] only if you select [Fold Only].
11" x 17"/LGL
LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
