Top » Quick Menu » Using the Quick Menu from the Machine » Editing a Personal Button/Shared Button
06RH-1AL
This section describes how to rename and delete registered Personal buttons/Shared buttons. As an example, the procedure for renaming and deleting Personal buttons is explained in this section.
Press (Quick Menu).
Press .
Press [Edit Buttons].
If you are editing the button name:
If you are deleting a Personal button:
Select [Personal] → select the Personal button to change → press [Rename].
Edit the button name and comment → press [OK].
For instructions on entering the button name and comment, see "Registering a Personal Button/Shared Button."
Press [Close].
Select [Personal] → select the Personal button to delete → press [Delete].
Press [Yes].
Press [Close].
The Administrator can delete the button information by logging in to the User Setting Information Management Service page from the Web browser. (See "User Setting Information Management (User Setting Information Management Service).")
