You can reserve copying while the machine is in the waiting state at the following times:
Between the time that you turn the machine ON and when it is ready to copy
After you clear a paper jam
Directly after you close a cover on the main unit or an optional unit, such as a finisher
(Start).
Be sure to correctly set the paper type. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
You can register paper types that are not displayed on the detailed settings list in <Change Multi-Purpose Tray Paper: Paper Type>. For more information on storing the paper type, see "Registering/Editing Custom Paper Types."
If there is more than one reserved job waiting to print, only the last paper size/type specified for the reserved print job appear on the Paper Select screen.
If [Register Multi-Purpose Tray Defaults] is set to 'On' in [Preferences] (Settings/Registration), the stored default values appear. (See "Registering Multi-Purpose Tray Defaults.")
[Transparency] can be selected only if you select [LTR] as the paper size.
To recall paper sizes from size buttons ([S1] to [S4]), register the paper sizes in advance. (See "Registering/Editing/Deleting Custom Paper Sizes.")
Make sure the Envelope Feeder Attachment for MP Tray is attached when feeding envelopes from the multi-purpose tray. (See "Loading Envelopes into the Multi-Purpose Tray.")
Select the correct placement and type for the envelopes. Failing to do so may cause a paper jam.
If you use envelopes that have glue attached to their flaps, the glue may melt due to the heat and pressure of the fixing unit.
(Start).|
Make sure to load the same paper size and type selected in step 4 into the multi-purpose tray. Copying does not start if paper of a different size or type is loaded.
You can reserve up to 20 copy jobs, including the current job. Interrupt copy jobs are not included in this count.
You can set different copy modes and paper sources, including the multi-purpose tray, for each reserved job.
If [Register Multi-Purpose Tray Defaults] is set to 'On' in Device Use Settings, reserved printing can be performed only for the registered paper size and type. (See "Registering Multi-Purpose Tray Defaults.")
For more information on paper types, see "Available Paper Stock."
