(Settings/Registration). |
Confirm the contents to be deleted.
If you select a button that already has settings stored in it, the settings are displayed.
If you make a mistake when entering values, press
(Clear) → enter the correct values. You can also name buttons with no settings stored in them.
For instructions on entering characters, see "Entering Characters."
If you press [OK] without entering any characters, the button name reverts to its current name (default S1 to S4).
The paper size settings stored in memory are not deleted, even if the machine's main power switch is turned OFF.
