Printer Connection Method (IPP/IPPS)
Windows XP/Server 2003/Server 2008/Vista/7/Server 2008 R2/8/Server 2012
In the following procedures, items displayed on the screens for Windows 8 are used. Depending on your environment, the items you see on the screen may differ.
The procedure for checking whether the IP address of the computer to install the driver in is allowed in the [Firewall Settings] of the machine is described in steps 13 to 16 of "TCP/IPv4 Settings," and steps 9 to 11 of "TCP/IPv6 Settings."
If communication via the relevant IP address is not permitted in [Firewall Settings], you cannot install the driver.
After you have installed the driver, if communication via the IP address of the computer you have installed it on is not permitted in [Firewall Settings], you cannot print or send a fax from that computer.
Start the Add Printer Wizard.
If you are using Windows XP Professional:
If you are using Windows XP Home Edition:
If you are using Windows Server 2003:
If you are using Windows Vista:
If you are using Windows Server 2008:
If you are using Windows 7/Server 2008 R2:
If you are using Windows 8/Server 2012:
From the [Start] menu, select [Printers and Faxes].
Click [Add a printer] for [Printer Tasks] → [Next].
From the [Start] menu, select [Control Panel] - [Printers and Other Hardware] - [Printers and Faxes].
Double-click the [Add a printer] icon → click [Next].
From the [Start] menu, select [Control Panel].
Double-click the [Printers] icon → click [Add a printer].
Double-click [Printer] → [Add Printer].
Click [Hardware and Sound] → [Add a printer].
Place the cursor on the top right (bottom right) of the desktop → select [Settings] → [Control Panel].
Click [Hardware and Sound]/[Hardware] → [Devices and Printers] → [Add a printer].
Specify the URL for the printer.
Select the type of printer → the printer connection method.
Windows XP/Server 2003: Select [A network printer, or a printer attached to another computer] → click [Next]. Select [Connect to a printer on the Internet or on a home or office network].
Windows Vista/Server 2008/7/Server 2008 R2: Select [Add a network, wireless, or Bluetooth printer] → [The printer that I want isn't listed] → [Select a shared printer by name].
Windows 8/Server 2012: Select [The printer that I want isn't listed] → [Select a shared printer by name].
Enter the URL → click [Next].
If you want to use regular IPP printing, enter the following URL.
http://<the IP address or host name of the machine>/ipp
If you want to use encrypted communication and perform IPPS printing, enter the following URL.
https://<the IP address or host name of the machine>/ipp
Click [Have Disk] on the screen for selecting the manufacturer and name of the printer → insert the CD-ROM that came with the machine into your computer.
4.
Specify the folder in which the printer driver is located → follow the instructions on the screen to complete the installation.
Mac OS X 10.5 - 10.8
If you are using the PS Printer Kit, and a PS printer driver provided by Apple Inc. with the Mac OS, you can use IPP as the print application. After installing the PPD file according to "Printing from a Computer (Mac)," specify the print settings according to the instructions in the documentation provided with your Macintosh.
When using IPPS printing with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012, it is necessary to obtain the public key of the machine and install it in Windows. For instructions on obtaining the public key, see "Obtaining the Public Key of the Machine to Use SSL with Windows Server 2008/Vista/7/Server 2008 R2/8/Server 2012 ."
If you are using Windows Vista, a dialog box may appear while you are performing the procedure. In this case, enter a user name and password. For more information, see the manuals provided with the operating system.
» Network » TCP/IP Network Setup Procedures » Setting Up a Computer for Printing/Sending a Fax » Printer Connection Method (IPP/IPPS)
0CYL-1R8
