TCP/IP Network Setup Procedures
To use a TCP/IP network, it is necessary to perform the following procedures.
1.Protocol Settings
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
2.Setting Up a Computer for Printing/Sending a Fax
Specify the settings of each computer you use for printing or sending a fax. (Optional equipment is required to print or send a fax from a computer. For the equipment needed, see "Optional Equipment and System Requirements.")
3.Setting Up a Computer as a File Server
Specify the settings of the computer receiving data sent from the machine.
It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 3.
The machine or printing equipment does not come with printer driver software that can be used on a UNIX platform. (Use LPD to set up a printer in UNIX.)
As the fax option does not come with fax driver software for the UNIX platform, it is not possible to send a fax from a UNIX platform.
Pre-determined ports must be opened in order to initiate network communication using TCP/IP. The required ports can be opened by selecting [On] for the appropriate [Network] settings in the machine. It is recommended that the settings for any unused functions be set to 'Off'. When a port is opened, it is possible for a third person to gain unauthorized access.
» Network » TCP/IP Network Setup Procedures
0CYL-1LC
