You can check, edit, or delete a specified destination before you scan your documents.
You can only change destinations specified using the New Address and destinations obtained via an LDAP server.
<ECM TX>, <Sending Speed>, and <Long Distance> do not appear when you specify a destination from the Remote Address Book.
Checking/Changing Information for the Specified Destination
Press [Fax] → specify the desired destinations.
Select the destination → press [Details].
Check or change the information for the destination as necessary.
If the destination has been specified from the Local Address Book or Remote Address Book:
If the destination has been specified from the Address Book (LDAP Server):
If you entered a new destination:
If the destination is a group address:
Check the information for the destination → press [OK].
Check and/or edit the information for the destination as necessary → press [OK].
The procedure to change the information is the same as when specifying a new destination. (See "Specifying Destinations Using the Address Book (LDAP Server).")
The procedure to change the information is the same as when entering a new destination. (See "Entering a New Fax Number.")
Select the group address → press [Details].
Select the destination from the group → press [Details].
Check the information for the destination → press [OK] → [OK].
Deleting a Destination
Select the destination → press [Delete Dest.].
If you want to edit a destination after scanning is complete, do it the Status Monitor/Cancel screen. (See "Checking and Canceling Send Jobs.")
» Fax » Sending/Receiving a Fax » Specifying Destinations » Checking/Editing/Deleting the Information for a Destination
0CYL-0S3
