Setting a Printer for Cascade Copying
You can register a printer for cascade copying, and check the information for and delete registered printers.
You can register up to seven printers for cascade copying.
If <Use IPv4> in [IPv4 Settings] in [Preferences] (Settings/Registration) is set to 'Off' (see "TCP/IPv4 Settings"), you cannot register a cascade copy printer.
Press [Function Settings] → [Copy] → [Register Remote Device for Cascade Copy].
To register a printer:
To checking the information for a registered printer:
To delete a registered printer:
Press [Register].
Enter the IP address for the printer to register using - (numeric keys) → press [OK].
Set the same Department ID and PIN as the machine for the cascade copy printer. (See "Specifying Department ID Management.")
Select the cascade copy printer that you want to check → press [Details].
Check the information → press [OK].
You can update the information for the cascade copy printer by pressing [Obtain Information] when the printer is restarted.
Select the printer to delete → press [Delete].
Press [Yes].
You cannot delete a cascade copy printer while cascade copying with the printer.
Press [Close].
» Settings/Registration » Function Settings » Copy » Setting a Printer for Cascade Copying
0CYL-08L
