To perform the procedure described in this section, you must log in to the machine as an administrator. (See "Logging In to the Machine as an Administrator.")
Prepare the License Access Number certificate that was included in the package.
The license key/license file can be obtained from the following website:
http://www.canon.com/lms/license/
The following information is required to obtain a license key/license file:
Serial number of the machine
The serial number is displayed in the bottom left of the screen when you press
(Counter Check) on the control panel of the machine.If your MEAP application does not come with a License Access Number, your license file will be provided by your MEAP Application provider. The license key and license file described in this section are not required. For more information, see the manual provided with each MEAP application.
It is recommended that you use the Remote UI if you want to install multiple system options.
(Settings/Registration).
(numeric keys).
Press to move the position of the cursor.
[Backspace]:
Press when you enter an incorrect number. The last number entered is deleted, enabling you to enter the correct number.
It is not necessary to specify an application file.
You can also specify the path of the license file by entering it directly.
License File:
A file with the 'lic' extension.
Application File:
A file with the 'jar' extension.
You cannot install only license files.
When installing a MEAP application, make sure you specify the license file. You cannot install the application without specifying the license file.
You can also specify the file path by entering it directly.
To use the installed MEAP application, you must start the MEAP application. For information on starting the MEAP application, see "Starting/Stopping Applications."
The maximum number of MEAP applications that can be installed is 19.
The maximum amount of hard disk space allocated to install MEAP applications is 1 GB.
There may be other system requirements for installation, depending on the MEAP application. For more information, see the manual provided with each MEAP application.
