You can add/delete files in memory media.
Adding a File (Scan and Store)
You can scan an original and store it as a file.
If you want to use the following resolution settings to scan a color image, it is necessary to expand the memory capacity of the machine with the Additional Memory Type A (512MB).
200 x 400 dpi
400 x 400 dpi
600 x 600 dpi
Place your originals.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the directory where you want to store the file → press [Edit File].
4.
Press [Add Files (Scan and Store)].
5.
Specify the desired scan settings.
6.
Press
(Start).
If the following screen is displayed, after the last batch of originals is scanned, press [Start Storing].
If you place your original on the platen glass, press
(Start) to scan each original.
Select the desired memory media → select the directory where the file you want to delete is stored.
Select the desired file → press [Edit File].
4.
Press [Delete].
5.
Press [Yes].
