(Settings/Registration).
You can register only one key pair.
The name of the generated/updated key pair is set to 'Device Signature Key'.
is displayed to the left of a key pair, it is corrupted or invalid. Follow the procedure in "Setting a Key Pair and Device Certificate" to generate/update a key pair.|
You cannot delete or edit a key pair necessary for a device signature on the Key and Certificate List for this Machine screen.
<Certificate Thumbprint> contains sender information used to validate the reliability of a PDF or XPS file with a device signature, by matching it with the SHA1 message digest number.
The expiration date for the device signature is set to 5 years after its key pair was generated/updated.
For information on how a general user can check the device certificate, see "Checking a Device Signature/User Signature Certificate."
