Note the following points when using the multi-purpose tray:
Paper Quantity: One to approximately (17 lb bond (64 g/m2), stack approximately 3/8" (10 mm) high)
Paper Size: 3 7/8" x 5 7/8" to 11 3/4" x 17" (99 mm x 148 mm to 297 mm x 431 mm)
Paper Weight: 16 lb bond to 80 lb cover (60 to 220g/m2)
Paper which has been rolled or curled must be straightened out prior to use, to allow the paper to feed smoothly through the multi-purpose tray (allowable curl amount: less than 3/8" (10 mm) for normal paper, less than 1/5" (5 mm) for heavy paper. There are some types of paper stock, which may meet the above specifications, but cannot be fed into the multi-purpose tray.
Make sure that you fan the sheets of paper well before placing them. Recycled paper, pre-punched paper, heavy paper, labels, and transparencies should be fanned particularly well before loading it.
Do not load different size/type paper at the same time.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper or transparencies, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
For high-quality printouts, use paper recommended by Canon.
If the paper size you are going to load into the multi-purpose tray is different from the paper size registered in [Register Multi-Purpose Tray Defaults] in [Preferences] (Settings/Registration), set [Register Multi-Purpose Tray Defaults] to 'Off'. (See "Registering Multi-Purpose Tray Defaults.")
When loading paper into the multi-purpose tray, align the paper stack neatly between the slide guides. If the paper is not loaded correctly, a paper jam may occur.
When loading paper into the multi-purpose tray, align the paper stack evenly between the slide guides. The paper may not be fed if the slide guides are set to a position narrower than the paper, causing the paper to curl.
If there are instructions on the paper package about which side of the paper to load, follow those instructions.
When the paper is loaded into the multi-purpose tray, the side facing down is the one printed on.
If problems, such as poor print quality or paper jams occur, try turning the paper stack over and reload it.
For more information on the print direction of preprinted paper (paper which has logos or patterns already printed on it), see "Relationship Between the Original Orientation and Paper Orientation."
If you use envelopes that have glue attached to their flaps, the glue may melt due to the heat and pressure of the fixing unit.
Take special care to spread the envelopes out in the direction that they will be fed.
Do not print on the backside of the envelopes (the side with the flap).
If the envelopes become filled with air, flatten them by hand before loading them into the multi-purpose tray.
The multi-purpose tray can hold five envelopes at a time.
If the envelopes do not pass through the machine properly even if the procedures up to this point have been followed, repeat the procedures by feeding once for each envelope.
Fold the flap before loading the envelope in the multi-purpose tray, as shown in the illustration.
Set the paper or envelope size to the same size as the paper or envelopes loaded in the multi-purpose tray.
To select an A or B series paper size, press [A/B-size].
If you make a mistake when entering values, press
(Clear) → enter the correct values.To select a registered paper size stored in a size button ([S1] to [S5]), you must store the irregular paper size in the size button beforehand. For instructions on storing irregular paper sizes, see "Registering/Editing/Deleting Custom Paper Sizes."
If the envelope type is not set correctly, a paper jam will occur.
Transparencies can be selected only if you select LTR as the paper size.
For more information on paper types, see "Available Paper Stock."
You can register paper types that are not listed in Detailed Settings for Selecting the Paper Type. For information on registering a custom paper type, see "Registering/Editing Custom Paper Types."
(Start). |
To cancel all settings and return the machine to the default mode, press
(Reset). The default settings are restored. However, even if you have selected files in [Access Stored Files], the files will be deselected. |
Feed tracing paper one sheet at a time, and remove each sheet as it is delivered to the output tray. Loading several sheets together may cause paper jams.
Depending on the type of heavy paper you want to load, if you load multiple sheets of heavy paper into the multi-purpose tray, a paper jam may occur. In this case, load only one sheet of heavy paper at a time.
If you are making two-sided prints, select the 2-Sided mode. The printed-paper may crease depending on the moisture absorption condition of the paper.
To print on the backside of preprinted paper, load the paper into the multi-purpose tray, and press [2nd Side of 2-Sided Page] on the paper selection screen that appears.
If you are printing on envelopes, do not allow more than 10 envelopes to accumulate in the output tray. Always empty the output tray once 10 envelopes have accumulated.
When scanning the following originals, you cannot use the Automatic Paper Selection mode. Use the Manual Paper Selection mode when scanning these types of originals:
Transparencies and other highly transparent objects
Originals with an extremely dark background
Envelopes may be creased in the printing process.
