0UKW-0A5
You can specify settings for certificates that are used to connect to the server.
Press
(Settings/Registration).
Press [Function Settings] → [Web Access] → [Settings].
Press [Security] → [Certificates].
4.
Specify the settings for the certificates.
If you want to enable or disable a certificate:
Select a certificate → press [Enable/Disable].
A check mark appears to the left of the certificate when it is enabled.
Press [Yes] → [OK] → [OK].
If you want to confirm the details of the certificate:
Select the desired certificate → press [Details].
The following details are displayed:
Issue Destination
Issuer
Expires
Serial Number
