e-ManualTopSite mapHelp
Top » Remote UI » Available Administrator Settings Table (Remote UI)
0UKW-0XR
If the administrator is specified, you can restrict operations by general users and allow the administrator to set the settings of each function on Settings/Registration. The settings available for operation vary according to the type of administrator. This section describes the settings in Settings/Registration that each type of administrator can operate.
For information on the types of administrators, see "Administrator Settings."
All users can set the settings in [Adjustment/Maintenance] (Settings/Registration).
Preferences
If the administrator is specified, the settings below in Preferences can be set only by the administrator.
: Only the administrator can change the settings.
-: Depending on the type of the administrator when using the SSO-H, settings cannot be changed.
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Restart Device]
[Paper Settings]
Paper Type Management Settings
[Timer/Energy Settings]
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Restrict Auto Reset Time
[Network Settings]
TCP/IP Settings
IP Address Settings (IPv4)
IP Address Settings (IPv6)
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
WSD Settings
IPP Print Settings
Multicast Discovery Settings
HTTP Settings
SSL Settings
Proxy Settings
Department ID PIN Confirmation Settings
IPSec Settings
NetWare Settings
SNMP Settings
Dedicated Port Settings
Spooler
Startup Time Settings
Ethernet Driver Settings
IEEE 802.1X Settings
AirPrint Settings
Firewall Settings
IPv4 Address Filter
IPv6 Address Filter
MAC Address Filter
IP Address Block Log
[External Interface]
USB Settings
Function Settings
If the administrator is specified, the settings below in Function Settings can be set only by the administrator.
[Common Settings]
Print Settings
Secure Watermark/Document Scan Lock Settings
[Printer]
Restrict Printer Jobs
PDL Selection (Plug-n-Play)
[Secure Print]
[Store/Access Files]
Network Settings
Protocol for External Reference
SSL Certificate Confirmation Settings for Network Access
Memory Media Settings
[Secure Print]
* The setting names may differ depending on the optional products available for use.
Management Settings
If the administrator is specified, the settings below in Management Settings can be set only by the administrator.
[User Management]
System Manager/Contact Person Information Settings
Department ID Management
[Device Management]
Device Information Settings
Certificate Settings
Key and Certificate Settings
CA Certificate Settings
Certificate Revocation List (CRL) Settings
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Key Operation Log Store Settings
Export/Clear Audit Log
Encryption Method Settings
[License/Other]
Message Board/Support Link
Remote UI Settings
Remote Operation Settings
ACCESS MANAGEMENT SYSTEM Settings
MEAP Settings
Register/Update Software
[Data Management]
Delete Existing Data Settings
Import/Export All
Import
Export
Import/Export Results
Import/Export Individually
Web Access Favorites
Printer Settings
Paper Information
